Is there a trigger for Simvoly "Added/Removed from Membership level"? If not, can we have one!
Status: Closed · Asked by RoCrow on · 0 views
I have Simvoly for my membership registration and Wishlist for the actual members site. I can have Simvoly send Wishlist new member info via Pabbly, but if a member cancels on Simvoly, I'm not sure how to send that info to Wishlist.
Is it currently possible? If not, can it be made possible?! :)
I have Simvoly for my membership registration and Wishlist for the actual members site. I can have Simvoly send Wishlist new member info via Pabbly, but if a member cancels on Simvoly, I'm not sure how to send that info to Wishlist.Is it currently possible? If not, can it be made possible?! :)
Did you try using the "New Contact Activity" trigger event for Simvoly?
Else, you can put request for adding new triggers here and upvote the same - https://pabbly.hellonext.co/
Yes, I tried that. Unfortunately it didn't pick up on me removing a Member from a Membership Level in the Simvoly dashboard. It could be that if the Member cancels themselves then it triggers but I'm not sure how to test that, but it doesn't trigger on manual, admin removal in Simvoly. I thought there might be a better way!
Hey @RoCrow
We have checked your desired case but it seems like Simvoly doesn't support the cancelation feature or send the data of the user who has canceled their membership.
So, it seems like you need to contact the Simovly team regarding the same.
Cool, thanks for that follow up!
