Is there a way: Create HubSpot contacts from new incoming WhatsApp messages?
Status: Closed · Asked by bogdasch on · 0 views
bogdasch — Question ·
Hello pabbly team, is there a way to create hubspot contacts from new incoming Whatsapp messages?
Maybe i go a step further: Create a contact with a unique ID, to send email marketing mails with the ID Merge like www.example.com/?id=*|unique-id|*.
With this informations i can send links that identify the customer, after they fill out a form on my website.
Thank you very much
BR Bogdan
Pabbly13 — Reply ·
Hey @bogdasch !
Sure, you can do that.
Kindly refer to this video tutorial on how you can extract the incoming data from WhatsApp-
youtube.com/watch?v=_yD9--12UFg:322
In the second step, you can add the HubSpot CRM step to add a contact, for which you can check for the second part of this video tutorial-
youtube.com/watch?v=6SWAM52yDD0:751
Hope, this can work for you.
bogdasch — Reply ·
thank you for your answer. Is it possible to get pictures out from whatsapp chats in my google drive folder?
No, the WhatsApp API's doesnt send any uploaded image in the trigger response, so I am afraid your use case is not possible.
