Is there a way to select a Custom GPT?
Status: Closed · Asked by TheLoyalOne on · 0 views
TheLoyalOne — Question ·
I'm using this to auto-gen blog articles which is working but merely using GPT-4. I'm needing it to use a Custom GPT though.
I don't see how via Pabbly nor how to by a prompt.
Does anyone know if this is even possible and if so, how?
tycoon1962 — Reply ·
Hi!
How can I use the earlier email conversations as a knowledge base to answer my email using ChatGPT Assistant?
Hello @tycoon1962
It is not possible to automate this using Pabbly Connect alone. We recommend consulting an expert developer to train a GPT model with your past email data. Once the GPT is trained, you can use the Open AI: Custom API Request in Pabbly Connect to automate answering emails based on the trained model.
Ok. Thank you.
