is there any issues with pabbly webhooks
Status: Closed · Asked by AFA on · 0 views
AFA — Question ·
its not working any update ?
Himesh Soni — Reply ·
It's working for me. Can you please double check with workflow history if still not working try to create new workflow.
Automation Freelancer
Email - [EMAIL][email hidden][/EMAIL]
AFA — Reply ·
It's working for me. Can you please double check with workflow history? if still not working try to create new workflow.
i have just found out that task not running
Consumed 0 Task
Consumed 0 Task
in which app you are using the webhook
AFA — Reply ·
in which app you are using the webhook?
taplink
taplink
can we connect on zoom It'll be free.
or you can check webhook url like this "your_webhook_url name=test" if it's coming in your pabbly connect workflow then webhook is fine.
