is there any issues with pabbly webhooks
Status: Closed · Asked by AFA on · 0 views
its not working any update ?
is there any issues with pabbly webhooksits not working any update
It's working for me. Can you please double check with workflow history if still not working try to create new workflow.
It's working for me. Can you please double check with workflow history? if still not working try to create new workflow.If you are still not able to solve this on your own feel free to DM me and we can do a free zoom call. FYI I'm not from Pabbly Connect team, just a freelancer who helps other Pabbly users.
i have just found out that task not running
Consumed 0 Task
Consumed 0 Task
in which app you are using the webhook
in which app you are using the webhook?
taplink
taplink
can we connect on zoom It'll be free.
or you can check webhook url like this "your_webhook_url name=test" if it's coming in your pabbly connect workflow then webhook is fine.
