Issue Connecting to Canva
Status: Closed · Asked by Christopher on · 0 views
I have the same issue!
I think there is something with your tutorial how to create an integration at canva ...
Hello @Christopher,
Please provide us with a short screen recording explaining the issue so we can better assist you.
PS: This thread has been moved to Private discussions to maintain confidentiality.
Hello @Christopher,Please provide us with a short screen recording explaining the issue so we can better assist you.
Hey @Preeti Paryani
This:
i did the same with incognito window and different browsers ...
Hello @Christopher,
Please allow us some time to look into this concern. We will get back to you with an update as soon as we have some.
Hello @Christopher,
Please set up the connection with Canva following the thread below and let us know how it goes.
Hello @Christopher,Please set up the connection with Canva following the thread below and let us know how it goes.
This is exactly what i did.
I get Error: "Some error occour (Authorization Code)"
This Authorization Code thing is not mentioned in the pabbly docu - so maybe something changed ?
And i attached you a Screenshot of the canva dev
Hello @Christopher,
Thanks for the explanation. Could you please try setting up a new connection by strictly following the steps mentioned in the shared documentation Make sure to select the scopes exactly as indicated to avoid any issues. Also, kindly record the setup process. If the issue still persists, share the recording with us so we can assist you further.
Hello @Christopher,Thanks for the explanation. Could you please try setting up a new connection by strictly following the steps mentioned in the shared documentation? Make sure to select the scopes exactly as indicated to avoid any issues. Also, kindly record the setup process. If the issue still persists, share the recording with us so we can assist you further.
You are the best :)
Now it worked ...
Send you a hug and a kiss !!
Thanks,
Hello @Christopher,
