Issue Connecting
Status: Closed · Asked by Araceli on · 0 views
Araceli — Question ·
Hi dears!
I am trying to connect the products of two Woocommerces, so that when one adds a new product the other mirrors it and gets the same product too. The idea is to be able to sync when new products and changes in stock when they happen.
For some reason, it is not working... The webhook on Web1 seems to be ok, but the information to be added in web 2 for the information requested ( Title, descriptions etc ) doesn't seem to be there... It only appears webhook 4.
Am I missing something? Can you guys help me?
Thanks!
Araceli
Araceli — Reply ·
I am checking and none of my webhooks work.. the trigger only shows webhooknrX, not the contents of creating a new product... that is toggling also the simple response. Any ideas why it might be?
Hey @Araceli
Regarding your above query, kindly re-capture the webhook response in the correct way from your WooCommerce. You can also refer to the following video tutorial for the same.
(Watch the first part of the video)
youtube.com/watch?v=wFp4bxkzrnQ
