ISSUE: Linkedin Leadgen Form Connection Puzin
Status: Open · Asked by puzin.dragana on · 0 views
Hi @raamanand,https://connect.pabbly.com/workflow/mapping/IjU3NjYwNTZmMDYzMTA0MzY1MjY0NTUzMjUxMzMi_pc
Before clicking the 'Save & Send Test Request' button, please submit a test lead as shown in the video shared below. Once the form is submitted, click the 'Save & Send Test Request' button and check if that resolves your issue.
Hi @ArshilAhmad,
I followed all instructions from the video and sent a test lead successfully but I still get the response value set as 0 - Same as @raamanand showed in the screenshot.
Hello @puzin.dragana,
We’ve moved the conversation to a new thread for better tracking.
Could you please share the workflow details where you're encountering this issue This will help us review it more effectively and provide accurate assistance.
Hi @Preeti Paryani ,
Thanks for reaching out so quickly.
I created a new workflow for capturing LinkedIn leads and sending them to Brevo.
I connected the LinkedIn account and selected the form from the dropdown.
I tried sending a test lead directly through add preview. In the add preview I get the message that the information was successfully sent.
Then I go to Pabbly and click save and send a test request and I get one response with the value 0.
When I try to submit another test lead that new information is not captured so only the first "lead" is captured but not with the correct response.
I also tried submitting the test lead directly though the form preview - same issue.
Sure, here it is: https://connect.pabbly.com/workflow/mapping/IjU3NjYwNTZiMDYzMzA0Mzc1MjZlNTUzMzUxMzYi_pc
Could you please make another lead submission, then click on the 'Save & Send Test Request' button and see if that resolves the issue?
It didn't resolve the issue. I recorded my screen to show you:
Pabbly Support | LinkedIn LeadForm issue
Watch Video
Thank you for sharing the screen recording.
It appears that your workflow is currently disabled. Could you please enable it and then try capturing the lead response again Once done, let us know how it goes so we can assist you further if needed.
Looking forward to your update.
I enabled the workflow. Submitted another test lead though LinkedinForm and clicked Save and Send Test Request. And the response is still not captured in Pabbly - I get Value 0.
In the video you shared above, you submitted the 'Brandcheck Test' form, whereas in your workflow, you have selected a different form. Please make sure to submit the same form that is selected in the LinkedIn trigger step.
Brandcheck test is just a placeholder ad title. The form in the ad selected is Test Form - Jun 24, 2025, same as the one in the trigger step in Pabbly.
It seems that the connection you are using does not have sufficient permissions to retrieve the leads data from your incoming lead form.To resolve this, ensure that the account has the appropriate admin role or Lead Gen Forms Manager permissions for the LinkedIn Page. If you're using a third-party tool to access the leads, check that the tool is properly authenticated and has the required permissions.
