Issue relating to matching the product
Status: Closed · Asked by Dr Sajjan Academy on · 0 views
Dr Sajjan Academy — Question ·
Work Group = #01 ECG - Concepts... (4)
work flow = #02= [Order Updated] [1 Year] - ECG Skill Level 1 : Concepts & Techniques
In Spayee we have a course and in that course, we have other 2 categories 1. Lifetime Validity and 2. 1 Year validity.
So the issue is we have used Woo Commerce as a trigger and next we have used filter and then Spayee Create Learner after that we need to enroll them with the course that they ordered in Woo Commerce but there is a single Course Page Url that also we have matched. As I told earlier we have 2 categories in the same course so how can we give access to the particular course that they order in woo Commerce
Hey @Dr Sajjan Academy
Please allow us some time to look into your concern and we will get back to you soon.
Dr Sajjan Academy — Reply ·
okay, sir.
We looked into your concern to add the subcategories of the course in the Spayee but in their API documentation, they haven't mentioned anything to do that.
If they can add the feature to their API documentation we will also add it to the current integration. You can contact their support team regarding the same.
Okay thank you sir
