Issue saving Mexican phone numbers in mobile field
Status: Open · Asked by enfasis on · 0 views
Hi team,
I’ve noticed an issue when creating contacts via the Chatflow API.
- When I send US phone numbers in the mobile field (e.g. 11234567890), they are correctly stored and appear in the Phone Number field of the contact profile.
- When I send Mexican numbers in the mobile field (e.g. 5216644162589 or +5216644162589), the contact is created successfully and the API response even returns the normalized value with +521..., but in the Chatflow UI the Phone Number field remains empty.
This prevents me from sending WhatsApp messages to Mexican contacts, since the Phone Number field is not being populated.
Could you please confirm what is the exact format expected for Mexican numbers in the mobile field so that they are properly recognized and saved in the Phone Number field?
Thanks in advance,
Hi @enfasis,
Please try using 5276644162589 as your phone number instead of 5216644162589 and see if that resolves the issue.
Hi team,
Thanks for your suggestion. However, I’d like to clarify an important point:
According to the E.164 international format, Mexican mobile phone numbers must be stored as:
+52 1 XXXXXXXXXX (10-digit local number)
For example:
- Local: 6644162589
- Correct international format: +5216644162589
If I use 527XXXXXXXXX as suggested, the number is no longer valid in E.164 and won’t be recognized by WhatsApp Cloud API, Twilio, or other providers.
Could you please confirm support for the standard +521... format in the mobile field so that the Phone Number field in Chatflow is properly populated?
This is crucial, because I need to make sure the numbers stored in Pabbly are correct and compatible with WhatsApp messaging.
Thanks in advance for your clarification,
Hello @enfasis,
Our team has recently implemented some fixes related to Mexican numbers. I recommend trying to add the number again as you were doing earlier and let us know if it now works fine for you.
