Issue while connecting Pabbly to Wordpress
Status: Closed · Asked by chiem on · 0 views
Hi guys, I'm having a issue connecting WordPress to Pabbly. I followed the instructions exactly ( installed the plugin called WordPress REST API Authentication, get Basic Authentication method configured too ). I tried many times, changed a new password or changed the base URL.
The thing is I met the same issue with Zapier, that's why I'm trying Pabbly. I have connected an other WordPress site to Zapier before and it went well.
Maybe the issue come from my new WordPress website? Please help to fix my case.
Hey @chiem
As we can see from your account, your WordPress account is set up correctly. So can you please try once and then let us know if the issue still persists?
Hi, im having the same problem, when I test in the WordPress REST API Authentication plugin the following error shows:
"code": "rest_no_route",
"message": "No route was found matching the URL and request method.",
"data": {
"status": 404
The rest API Endpoint is:
Hey @DistritoDO
Can you please share the workflow URL once, so that we can look into the action step and guide you accordingly?
"I had the same issue with invalid credentials or base URL. I reset WordPress and now I'm getting an error
"data": {
"status": 404
} in the API plugin. I've run multiple tests on different domains as well."
I don't know what else to do, and I'm very interested in completing the integration so that the client can view and purchase the service
Hey @irvingmarc
Can you please share your workflow URL with us where you have performed the action step so we can look into it and guide you accordingly?
