Issue with an matching of responses
Status: Closed · Asked by quepreonpay on · 0 views
quepreonpay — Question ·
Work Flow Name - #06 Elementor To WooCommerce
wooCommerce as a Action event- we have match all the fields and in customer ID we are unable to match the field. if we leave as it is then in wooCommerce orders it will matched customer ID with another Mail ID
Hey @quepreonpay
You need to map the ID of the customer on the "Customer ID" field by opening the map button to make the workflow dynamic.
quepreonpay — Reply ·
So we need to type it as 637 in that field right
Hey @quepreonpay
You need to map the Id on the "Customer ID" field.
Can you please be clear because we are unable to map this
Hey @quepreonpay
Please check out the following screenshot for a better understanding. I hope this might help you out.
