Issue with automatic Trigger in Airtable
Status: Closed · Asked by Support - FINSPRO FINANCE on · 0 views
Hi Team,
currently (maybe it is related to the general connection issue from yesterday from multiple users with Pabbly Connect & Airtable) our Workflows (both have initial triggers from Airtable) are not recognizing the updated record and therefore they are not processing at all.
When i go manually in there the record is not found at first, then i see the connection for the right base / table is not working properly.
After reconnecting (only resetting the same settings like before, the manual search in workflow builder finds the records and works without any issues.
This is the same for both workflows.
One: https://connect.pabbly.com/workflow/mapping/IjU3NjYwNTY4MDYzNzA0Mzc1MjZmNTUzNjUxMzYi_pc
Two: https://connect.pabbly.com/workflow/mapping/IjU3NjYwNTY4MDYzNzA0Mzc1MjZlNTUzNDUxM2Ii_pc
Also it seems currently sometimes the whole internet page freezes (only the tab with Pabbly) without any reason.
Can you please double check and let me know if there is anything wrong internally still with Airtable or platform in general?
Thank you.
Regards
Christian
Hi @Finspro,
The Airtable connection issue has now been resolved.
Please create a new connection with your Airtable account in both workflows and check if this resolves the issue of the workflow not triggering.
