Issue with data not parsing correctly when pulling from multiple sources
Status: Open · Asked by dodgenvy on · 0 views
dodgenvy — Question ·
I am creating a custom .ics calendar event, and there is an issue with all of the data parsing in time for the file to be created.
Similarly, in another workflow, I have built the same issue persists where data comes in inconsistently or appears missing/null, creating empty values near the end of the flow.
Has anyone had issues with values appearing null when you are pulling data from multiple sources? Unlike n8n, there is no node where you can create a collection of data values from numerous sources and create fallback values in the case of failures or null values, which I find a bit frustrating.
Hello @dodgenvy,
Could you please provide us with the Workflow URL where you are facing this issue This will help us investigate the problem more effectively and assist you accordingly.
dodgenvy — Reply ·
I can provide the URL, thank you: https://connect.pabbly.com/v2/app/workflow/mapping/IjU3NjYwNTY1MDYzNjA0M2Q1MjZhNTUzMTUxMzMi_pc
Also, for reference, I am using 2 code nodes, and I saw that support would not be provided for anything code-related, but on my end, the code is validated, so the issue I have found is with the way each collection of data is sent to these nodes and improper mapping causing the .ics file to appear empty/unformatted.
[email hidden] (my account is [email hidden], but the workflow is under the Angie account).
Hello @dodgenvy,
Thank you for sharing the workflow URL. However, upon reviewing it, we are not able to identify the exact issue, as the workflow you provided has never been executed completely and always stops at the filter step. Because of this, it’s difficult for us to understand where the data is coming in inconsistently.
Could you please share a short screen recording showing the workflows where you are capturing the data from multiple sources and how the values are appearing as null or inconsistent This would help us understand the issue much better and provide you with the right guidance.
