Issue with Lookup
Status: Closed · Asked by Real Estate Integrate Inc. St. Hilaire on · 0 views
Real Estate Integrate Inc. St. Hilaire — Question ·
Task History ID: IjU3NmQwNTZkMDYzZjA0Mzc1MjY0NTUzNjUxMzU1MTYwNTQzOCI_3D_pc
This issue has happened several times now and I've messaged you about it and it's still happening. Can you please fix this once and for all?!
Hey @andrewstrealtor
Could you please provide the specific task history ID mentioned in the screenshot? We are unable to locate the value in the task history provided earlier.
Real Estate Integrate Inc. St. Hilaire — Reply ·
IjU3NmQwNTZkMDYzZTAoMzI1MjY4NTUzZDUxM2E1MTY1NTQzMCI_3D_pc
This is issue continues
I have forwarded your concern to the technical team and they are working on it.
Our technical team has implemented some modifications in the action step, and it should now function as intended.
