Issue with Multiple TradingView Alerts to WhatsApp Notification Integration
Status: Open · Asked by Amal on · 0 views
We are integrating TradingView alerts with WhatsApp notifications using the Aisensi WhatsApp API. We’ve successfully set up webhooks and got our templates verified with Meta.
Issue:
- Pabbly Connect Test: Notifications were received as expected.
- TradingView Test: The first alert triggered a WhatsApp notification correctly.
- Multiple Alerts Issue: However, when creating a second alert for the same asset (Bitcoin), we don’t receive the notification. Only the first alert works, and subsequent alerts do not trigger WhatsApp notifications.
We would appreciate your help in resolving this so that we receive notifications for all alerts, including multiple alerts for the same asset.
Also, could you confirm:
- Will TradingView alerts still send notifications to WhatsApp if the TradingView website is closed?
We are using the TradingView paid version and the Aisensi WhatsApp API.
Please find the workflow diagram attached for reference.
Hello @Amal,
We recommend using the Send Template Message (Beta) action instead. Please try it out and let us know if it works for you.
You can take reference on how to use this action from forum threads - https://forum.pabbly.com/search/690278/ q=Send+template+Message+%28Beta%29&o=relevance
