Issue with Pabbly Connect -> Pipedrive
Status: Closed · Asked by Julian on · 0 views
Julian — Question ·
Hi everybody,
I have a really annoying problem with the Pabbyl/Pipedrive-Connection:
Pipedrive limits the number of Requests that can be done per Second. This can be seen in this screenshot:
Because of that limitation I am constantly running into problems. Mostly when importing anything or changing a large group of data with a filter, as this makes way more changs then 20 per second.
The easiest way to solve that would be somehow to limit the max-executions per second of Pabbly with a Pipedrive-Connection. I already tried such a lot of workarounds, but it seems none of them would work. Is there a way to throotle Pabbly so it works seamlessly with Pipedrive?
All the best, Julian!
Hey @Julian
It seems like the limitation is from your Pipedrive plan which you are having since the rate limits are different from their subscription.
Kindly select the subscription which allows more requests per 2 seconds.
