Issue with Sync products from Shopify to Woocommerce
Status: Closed · Asked by Araceli on · 0 views
Hi dears,
I am doing everything that is said in the video, but for some reason is not working...
Also, how do we sync images when there is more than one?
Is it possible to sync the stock levels with Pabbly too? (like once the product is created, only to be able just to keep the stock updated- no need for the rest of information to be updated)
Thanks a lot!
Hey @Araceli
You can only pass a single image only in the Woocommerce action step at a time. Though you can pass multiple images then you always have to make sure that you have put the exact number of images that you have initially set up.
mmm.. How can I do the part of the images then? is there a video I can learn how to do it? ... It would be really great to totally sync the products.
In any case, even with only one image, it doesn't seem to work... Not sure what I am doing wrong... I am adding a screenshot.. Please assist me.
Thanks a lot Supreme!
Hey @Araceli
Could you please re-capture the webhook responses in advance response by toggling the "Simple Response button" which will capture the whole data in JSON array then we can check the possibility of your concern?
Kindly make sure you are passing more than 2 Images on that.
