Issue with Task Execution on Unlimited Plan
Status: Open · Asked by Akash Badiyani on · 0 views
Hello Pabbly Support Team,
We are currently using the following plan on Pabbly Connect:
Pabbly Connect 2-Yearly Plan - Unlimited Plan (INR) (HSN Code: 997331)
We are facing an issue with task execution in our workflows. As per our understanding, the plan provides unlimited task execution, but sometimes our workflows suddenly stop executing tasks.
After some time, usually the next day, the tasks start resuming automatically again without any changes from our side.
Because of this, some of our workflows are not executing properly in real time, which is affecting our operations.
We would like to understand:
- Is there any daily execution limit or hidden restriction on the Unlimited Plan?
- Why are the workflows stopping temporarily?
- Is there any queue, throttling, or fair usage policy applied to task execution?
- How can we avoid this issue in the future?
Please help us understand the reason for this behavior.
Thank you.
Hi @Akash Badiyani,
In Pabbly Connect Unlimited plans, we show an initial limit of 100,000 tasks; however, your tasks are truly unlimited. You can reset the task count once you consume 80% of your initial task limit. This safeguards our systems and helps prevent system abuse or infinite loops.
https://forum.pabbly.com/threads/pabbly-connect-constraints-rate-limits.10670
There are no such daily limits or hidden restrictions other than the one described above, and we can see that you are not hitting that limit.
Could you please share the workflow that stopped temporarily, along with the time at which it stopped receiving data and triggering, and when it started working again?
We would need you to share the information requested above before we can comment on what exactly the issue is.
Arshil Ahmad
How to reset task count onces 80% consumed ?
Hey @Akash Badiyani,
You can do that by following the steps below:
- Navigate to the Setting > Task Summary Page in your account.
- The Reset Task button becomes clickable once 80% of your task quota is used.
- Users can reset their task count once per day.
- Clicking the button resets the consumed task count to 0 immediately.
For more info, please check this thread - https://forum.pabbly.com/threads/pabbly-connect-task-reset-policy-when-does-my-task-count-reset.17614/
