Issue with Tidycal connection
Status: Closed · Asked by Antony Chacko on · 0 views
I am getting this error literally every week:
{"message":"Unauthenticated.","OAuthException":{"error":"invalid_request","error_description":"The refresh token is invalid.","hint":"Token has been revoked","message":"The refresh token is invalid.","ErrorTip":"Try creating a new connection to resolve the OAuthException error. Learn more: https:\/\/forum.pabbly.com\/threads\/how-to-solve-oauthexception-error.18724\/"}}
I am creating new connection as soon as I get this message, then again the next week the connection breaks and I have to create new connection again. I need a permanent fix for this. Please help.
Hey @Anthony
Can you please share the workflow URL once in which you have tried the same so that we can look into it?
Hey @AnthonyCan you please share the workflow URL once in which you have tried the same so that we can look into it?
Here you go https://connect.pabbly.com/workflow/mapping/IjU3NjcwNTY1MDYzMDA0M2Q1MjZlNTUzNCI_3D_pc
Hey @Antony
We have made a slight change from our end in the Tidycal and then tried the integration again by making a new connection.
I hope this might help you out.
I have the same issue in another tidycal workflow https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTY5MDYzMjA0MzA1MjY5NTUzNzUxMzQi_pc
Can you fix it and also let me know what exactly is the fix so that I can implement that in the future
It should also work the same in all the Tidycal steps. Please reconnect it and then try again.
We have made a small change in the connection page at our end.
