Issue with Webhook Handling Array Format from Voice Bot - Need Assistance
Status: Open · Asked by Anil Botta on · 0 views
I am currently working on a project where a voice bot (built using Vapi) is configured to send order information in an array format to a Pabbly Webhook. While the array is being sent correctly from the bot, I am facing an issue where the Pabbly Webhook appears to cache or split the order items individually rather than recognizing and passing them as a complete array.
What We Are Trying to Do
We are building a system where:
- A voice bot (built using Vapi) takes customer food orders over a phone call.
- The bot captures the entire order in JSON array format and sends it to a Pabbly Webhook.
- From Pabbly, we want to send the full order to Clover POS (sandbox) via API in a single request.
Issue Summary:
- The voice bot captures the entire order as an array (e.g., ["1 chicken biryani", "2 butter naan", "1 chicken biryani"]) and sends it to the Pabbly Webhook.
- However, in Pabbly, instead of treating the array as a single object or line item group, it separates each value as Result 0, Result 1, Result 2 etc., under the “Response Received” section.
What I Tried:
- Used the split text step to isolate and map each item (works, but not scalable).
- Tried to skip the iterator step and send the full array as-is.
- Attempted using custom request and webhook forwarding to Clover POS.
- Re-validated that the array format from Vapi is correct (confirmed with JSON structure and schema).
Despite these steps, Pabbly is not handling the full array as expected for further processing or API integration.
Request:
Could you please assist or advise:
- How can we ensure Pabbly handles the incoming array properly?
- Is there a way to access or map the entire array as a single object within Pabbly Webhook or the next step?
- Any recommended method or workaround to forward the array as-is to third-party APIs (e.g., Clover)?
I’d greatly appreciate your guidance on how to resolve this issue.
Thank you for your support!
Best regards,
Anil Botta
[email hidden]
Hello @Anil Botta,
Could you please provide us with the Workflow URL where you are facing this issue This will help us investigate the problem more effectively and assist you accordingly.
[IMG width="623px" height="187.699px"]https://lh7-rt.googleusercontent.com/docsz/AD_4nXeSJygO18lgoKquDlc7kt_gqc6IegIRep_gbSOdXCUr0jIBH8s92RDedowyFV3nSNQHryv0vV99bF9YnrpSplgV-LJrmAgdLy1uMruwr2dkxSJXDfgAuuY3UCNx-1qmuPP_wnm7 key=PL4GUVQWZ8u13PditD4i_cYb[/IMG]
Hello Preeti,
Thank you for reaching out.
Please find below the Workflow URL where we are currently facing the issue: ? Workflow URL
Issue Description:
We are working on a voice bot that captures customer order data and sends it as a JSON array of strings using a webhook. The array looks like this:
["Butter Naan", "Paneer Tikka", "Mango Lassi"]
We are attempting to iterate over this array using the Iterator in Pabbly to handle each item individually.
However, the iterator does not split the array into individual values as expected. Instead, it processes the entire array as a single string, making it difficult to take action on each food item separately.
We suspect that the input format might not be correctly recognized by the Iterator or there may be a configuration step we are missing.
Your guidance on how to properly set up the iterator for parsing this type of array would be greatly appreciated.
Thanks and Regards,
Anil Botta
I am attaching the voice bot webhook logs to demonstrate that the voice agent is correctly sending the information in an array format.
Hello @Anil Botta,
It looks like some changes have been made within the workflow, and we are unable to find the iterator. Could you please confirm if you're still experiencing the issue If so, kindly provide the workflow URL so we can investigate further.
the above is the URL
can you please check this url
I am currently working on a project where a voice bot (built using Vapi) is configured to send order information in an array format to a Pabbly Webhook. While the array is being sent correctly from the bot, I am facing an issue where the Pabbly Webhook appears to cache or split the order items individually rather than recognizing and passing them as a complete array.What We Are Trying to Do
Issue Summary:
What I Tried:
Despite these steps, Pabbly is not handling the full array as expected for further processing or API integration.Request:
I’d greatly appreciate your guidance on how to resolve this issue.Thank you for your support!
Best regards,
Anil Botta
[email hidden]
Did you try turning off Simple Response toggle in trigger step and re-capturing the response That should solve the issue.
Hello @Anil Botta,
I’m unable to locate a similar array in the current response. Please try capturing the response in Advanced Format by turning off the Simple Response toggle button. Once done, click on the Re-Capture Webhook Response button to capture the response again.
After that, you can use an Iterator to process the array accordingly.
I tried many times to recapture it, but with no result. Do you have any video that I can follow to understand the workflow for creating an order in the Clover app through the voice bot?
Hello @Anil Botta,
As Vapi has been recently added, we currently do not have a dedicated tutorial available for it.
However, could you please confirm whether you’ve successfully captured the response in Advanced format If you're facing any issues during this step, do let us know — we’ll be happy to assist you accordingly.
