Issue with WooCommerce and ZOHO Bigin CRM
Status: Closed · Asked by quepreonpay on · 0 views
WorkGroup - #10 Bigin CRM (1)
Work Flow - 15Feb2022 - Woo Commerce To Bigin CRM
We have made an automation that, when ever the data comes to an New Cart Abandonment that data as to reflect in Zoho CRM but the issue is what ever the response that came from the trigger that same data is reflecting again and again in the Zoho CRM. We are having different data in Cart Abandonment but in Zoho CRM all datas are similar one.
Please check the Workflow history.
Hey @quepreonpay
It seems like you have made some changes afterward, though the workflow seems fine to use.
Further, previously you haven't mapped the contact Id in the Contact field of the " Zoho Bigin: Create Contact Deal" action step. Though we have mapped that for you so now it will not get assigned to the same contact again.
If the issue persists in your workflow then kindly recapture the webhook response and remap the fields again.
You have only create contact but we wanted create Deal Contact too in the Bigin CRM
Hey @quepreonpay
Regarding your concern, it will require a different action event of Zoho and for this, you need to post a request here -
Our Integration team will look into it.
Hey @quepreonpay
Regarding your request, could you please tell us once that do you want to assign deals while creating a contact? Also if you can share the reference regarding the same do let us know.
