issues with 360dialog integration
Status: Open · Asked by Salil Chaudhary on · 0 views
facing issues regarding 360dialog integration. Whatsapp messeges are not being sent . new API key showing invalid. is it with pabbly or 360dialog ??
Hi @Salil,
I ahve the same problem. Pabbly team asks to contact 360dialog and 360 asks to contact pabbly team
No help is being given. Earlier the integration used to work just fine but since 3-4 months, its not working at all.
Can you please share the workflow URL on which you have tried the 360 Dialog action step, so that we can look into it?
https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTY5MDYzZjA0MzA1MjY4NTUzMjUxMzQi_pc
It seems that the WhatsApp number you are using is not configured correctly with your 360 Dialog account or may not be registered properly.
We recommend contacting the 360 Dialog Support team for assistance. They can help you correctly configure and register your phone number with your account.
You may also refer to their API documentation for the same -
https://docs.360dialog.com/docs/waba-messaging/contacts-and-location-messages
