Issues with Sending Multiple Checkbox Values to Pabbly Connect Webhook via AJAX Call
Status: Closed · Asked by abul dev on · 0 views
abul dev — Question ·
I have been integrating Pabbly Connect with my application for a long time without any issues. Recently, however, I encountered a problem when sending data to the Pabbly Connect webhook using an AJAX call. Specifically, I have a checkbox field that allows multiple selections. When I select multiple values and send the data using an AJAX call like checkbox=val1&checkbox=val2, Pabbly Connect only captures the last value (val2) and ignores the others.
This issue has only started occurring recently, and I am unsure what might have changed to cause this. Has anyone else experienced this problem, and is there a known solution or workaround for properly sending multiple checkbox values to Pabbly Connect? Any help or insights would be greatly appreciated.
tohid_001 — Reply ·
I am also facing the same issue
Hey @abul dev
Please verify it using a webhooks testing platform known as webhook.site. Copy the webhook URL from Webhook.site into your application, and trigger a test event to see if the webhook functions correctly on Webhook.site. This will help confirm the issue. Could you also provide us with the dummy incoming data that is not being processed as expected?
Here is a sample video that you can follow to track the webhook issue:
https://webhook.site/#!/296c8add-efd8-4849-b03e-654fa108793c
youtube.com/watch?v=mnJFZxwhiEQ
Hey @abul dev
When passing multiple favGames parameters through a webhook URL, only the last value is received. This is because the URL encoding does not handle multiple parameters with the same name well.
Solution:
  1. Combine values into a single parameter:
    Name=Abul&email=abul%40dev.io&favGames=football,cricket
    Parse the combined value on the receiving end.
  2. Use array syntax (if supported):
    Name=Abul&email=abul%40dev.io&favGames[]=football&favGames[]=cricket
    Ensure the receiver is designed to handle arrays.
Select the method that aligns with the capabilities of your webhook-sending application.
abul dev — Reply ·
Hey @Supreme
We've been using this setup for two years without encountering this issue. My question now is whether this issue has existed since the beginning or if it's a recent development.
I can implement either of the proposed solutions, but each comes with its own set of challenges. If this issue is related to Pabbly Connect, we will request their support to address and resolve it. If it turns out not to be their responsibility, then I'll proceed with one of the suggested solutions.
Thank you.
The issue you're experiencing with receiving only one favGames parameter is not new; it’s how webhooks typically handle repeated parameters. When multiple parameters with the same name are passed, only the last value is retained. This behavior is consistent and not a recent development.
To address this, you can implement either of the following solutions:
    This way, you can parse the combined value on the receiving end.
  2. Use array syntax (if supported by the receiver):
abul dev — Reply ·
Hey @Supreme
I wanted to take a moment to thank you for your help with the pabbly connect issue I was facing. Your suggestions were very helpful, and I appreciate the time you took to assist me.
Thank you again for your support!
