iTERATOR NOT CONVERTING DATA WHICH IS REQUIRED IN JSON FORMAT
Status: Closed · Asked by Study Cafe on · 0 views
studycafe — Question ·
Dear Team, I need to send bulk messages and for that i am using this video
youtube.com/watch?v=H0aBHNl2ICc
Problem is that iterator is not converting the data which is required i Json format. REfer attached screen shot.
Kindly suggest what to do?
Fagun Shah — Reply ·
youtube.com/watch v=H0aBHNl2ICc
No need to use JSON extractor anymore, you can use/map values from Iterator results directly now.
Watch video after JSON step, your iterator output should work similarly as JSON Extractor action step output from video.
Fagun Shah
- Automation Freelancer
