Iterator not processing all values
Status: Open · Asked by Bryan Grasso-Shonka on · 0 views
SnackGuy — Question ·
Task History ID: IjU3NjUwNTY1MDYzMTA0M2M1MjZkNTUzMjUxMzA1MTYxNTQzNjBmMzAi_pc
I have a json output that has 1309 rows (equivalent). Yet when I run the workflow to update a database using the data from the iterator, it only runs for 12 rows and none of the rest.
What would I have to adjust to get it to run for all the rows.
Hey @SnackGuy,
Upon checking the array mapped in the Iterator, it appears only 10 objects/rows are being received in the input. We have executed the workflow for all the available items from this array.
Please refer to the attached screenshot for better clarity.
Iterator is not Working!!! Please Help. I tried it several times but Nothing is there to select.
Screen Recording of Iterator not working
You need to select the 'Advanced' format, then click on 'Save & Send Test Request'. This will allow you to capture the response in the form of an array, which will then be recognized by the Iterator.
Arshil Ahmad
?Rate your support
