Iterators and cycling through lists question
Status: Closed · Asked by Niche Web Marketing on · 0 views
I know how to process an array using an iterator, but my question deals with larges chucks of information where they only deliver a certain number of results in the array and then they include the next starting after ID so you can get the next array. I'm limited to 100 results in an array, but I have 800 total records to go through, so how would I configure this so I could cycle through all 800 records in batches of 100? If you go into the task, this is just a testing area and the step number is 8 list leads and then the iterator is step 9, but I need to utilize the "next starting after" in step 8 to pull the next 100. Thanks!
Hi @nicheweb,
Are you looking to iterate through multiple action steps — for example, iterate the data in Step 8, then Step 10, then Step 11, and so on? If so, I'm afraid this particular use case isn't possible. You cannot use the same Iterator to loop through the data of multiple action steps.
Hi @nicheweb,Are you looking to iterate through multiple action steps — for example, iterate the data in Step 8, then Step 10, then Step 11, and so on? If so, I'm afraid this particular use case isn't possible. You cannot use the same Iterator to loop through the data of multiple action steps.
I just want to be able to cycle through all of the data and use it so it doesn't necessarily have to use the iterator. Since the API only allows us to get 100 records at a time in an array and then provides us with the next starting id, is there a way to cycle through all of that data so we can get all of it? Thanks
The Iterator will process all the data fetched in your action step upon execution of the workflow. If the action application doesn't send all the data at once, then it's not possible to process the next set of data through the Iterator unless the entire workflow is triggered again.
@nicheweb you need to watch this video of mine -
