it's not sending messages when we are using Arrayformula-vlookup in trigger column
Status: Closed · Asked by Shubham sharma on · 0 views
Shubham sharma — Question ·
it's not sending messages on telegram when we are using Arrayformula-vlookup in the trigger column, because it's not found that trigger column cell empty is anyone have any idea to resolve it?
Hey @Shubham sharma
Implementing formula on the triggering column on the Google Sheets which is being used to trigger the data is not preferable. So, kindly avoid using the formulae on the sheets which are being triggered.
Shubham sharma — Reply ·
Hey @Shubham sharma
then how can I use logicals to get related data?
Hey @Shubham sharma
You can use the simple data through Google Sheets to manage the data on the platform. And using formulas is not permissible, since the data can only be forwarded through the Google Sheets to Workflow without formula on it.
Regards!
