Jumpseller Integration with Pabbly Connect
Status: Closed · Asked by Abhishek Bansal on · 0 views
This documentation offers a comprehensive, step-by-step guide to integrating your jumpseller account with Pabbly Connect. By following these instructions, you can effortlessly establish a seamless connection between the two platforms.
How to authorize Jumpseller in Pabbly Connect?
- Within Pabbly Connect, navigate to the trigger step and choose "Jumpseller" as the trigger you wish to perform. Select a trigger event, such as "Product Update".
- Log in to your Jumpseller account.
- On the left side of the dashboard , click on "Settings," proceed to the "General" section, then select "Notifications,".
- Select the event as "Product Updated" from the Event dropdown.
- Copy the Webhook URL above & paste it under the "Callback URL" field.
- Provide a name to the webhook under the "Name" field, and click on the "Add" button.
TRIGGERS:
Jumpseller: Product Deleted(Trigger Event)
Please follow below the steps to capture the trigger response to product Deleted for the above-mentioned trigger event:
- Navigate to the left sidebar, click on "Settings," proceed to the "General" section, then select "Notifications," and select "Webhooks."
- Select the event as "Product Deleted" from the Event dropdown.
- Click the "Capture Webhook Response" button below and perform a test record to ensure the webhook response is captured here.
Jumpseller: Create customer (Action Event)
Please follow the steps below to create a new Customer in your selected application for the mentioned action event. -
- Use Case: To create a new Customer in your Jumpseller account.
- Select "Create Customer" as an action event, connect your Jumpseller account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Jumpseller in Pabbly Connect?" section.)
- Select/Map the "Email", "Name", and all other required fields.
- Click on "Save and Send Test Request".
Jumpseller: Create Product (Action Event)
Please follow the steps below to create a new Product in your selected application for the mentioned action event. -
- Use Case: To create a new Product in your Jumpseller account.
- Select "Create Product" as an action event, connect your Jumpseller account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Jumpseller in Pabbly Connect?" section.)
- Select/Map the "Name", "Price", and all other required fields.
Jumpseller: Create New Product Image (Action Event)
Please follow the steps below to create a new Product Image in your selected application for the mentioned action event. -
- Use Case: To create a new Product Image in your Jumpseller account.
- Select "Create New Product Image" as an action event, connect your Jumpseller account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Jumpseller in Pabbly Connect?" section.)
- Select/Map the "Product ID", "Image Url", and all other required fields.
Jumpseller: Create Product Option (Action Event)
Please follow the steps below to create a new Product option in your selected application for the mentioned action event. -
- Use Case: To create a new Product Option in your Jumpseller account.
- Select "Create product Option" as an action event, connect your Jumpseller account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Jumpseller in Pabbly Connect?" section.)
- Select/Map the "Product ID", "Name", and all other required fields.
Jumpseller: Create A New Fulfillment (Action Event)
Please follow the steps below to Create a new fulfillment in your selected application for the mentioned action event. -
- Use Case: To Create a new Fulfillment in your Jumpseller account.
- Select "Create a New Fulfillment " as an action event, connect your Jumpseller account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Jumpseller in Pabbly Connect?" section.)
- Select/Map the "Order ID", "Type", and all other required fields.
Jumpseller: Retrieve Customer by ID (Action Event)
Please follow the steps below to Retrieve Customer by ID in your selected application for the mentioned action event. -
- Use Case: To Retrieve Customer by ID in your Jumpseller account.
- Select "Retrieve Customer By ID" as an action event, connect your Jumpseller account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Jumpseller in Pabbly Connect?" section.)
- Select/Map the "Customer ID".
Jumpseller: Search Customer by Email (Action Event)
Please follow the steps below to Search Customer by Email in your selected application for the mentioned action event. -
- Use Case: To Search Customer by Email in your Jumpseller account.
- Select "Search Customer by Email" as an action event, connect your Jumpseller account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Jumpseller in Pabbly Connect?" section.)
- Select/Map the "Email".
Jumpseller: search Product (Action Event)
Please follow the steps below to Search Product in your selected application for the mentioned action event. -
- Use Case: To Search Product in your Jumpseller account.
- Select "Search Product" as an action event, connect your Jumpseller account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Jumpseller in Pabbly Connect?" section.)
- Select/Map the "Product ID".
Jumpseller: Retrieve Order by ID (Action Event)
Please follow the steps below to Retrieve Order by ID in your selected application for the mentioned action event. -
- Use Case: To Retrieve Order by ID in your Jumpseller account.
- Select "Retrieve Order by ID" as an action event, connect your Jumpseller account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Jumpseller in Pabbly Connect?" section.)
- Select/Map the "Order ID".
Jumpseller: Retrieve all Product option (Action Event)
Please follow the steps below to Retrieve all Product option in your selected application for the mentioned action event. -
- Use Case: To Retrieve all Product Option in your Jumpseller account.
- Select "Retrieve all Product Option" as an action event, connect your Jumpseller account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Jumpseller in Pabbly Connect?" section.)
Jumpseller: Update Customer (Action Event)
Please follow the steps below to update Customer in your selected application for the mentioned action event. -
- Use Case: To Update Customer in your Jumpseller account.
- Select "Update Customer" as an action event, connect your Jumpseller account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Jumpseller in Pabbly Connect?" section.)
- Select/Map the "Customer ID", "Email", and all other required fields.
Jumpseller: Update Product (Action Event)
Please follow the steps below to update Product in your selected application for the mentioned action event. -
- Use Case: To Update Product in your Jumpseller account.
- Select "Update Product" as an action event, connect your Jumpseller account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Jumpseller in Pabbly Connect?" section.)
Successful Integration:
Upon completing the above steps, your Jumpseller account will now be successfully integrated with Pabbly Connect. You can utilize different actions and triggers according to your purpose. With this integration, you can automate processes through Pabbly Connect, improving your workflow and enhancing your productivity.
If you encounter any issues or require further assistance, feel free to reach out to our support team for help. ([EMAIL]support@pabbly.com[/EMAIL])
Happy integrating!
