Klaviyo integration
Status: Closed · Asked by olimckenna on · 0 views
olimckenna — Question ·
Task History ID: IjU3NjUwNTY4MDYzMDA0MzU1MjZkNTUzNjUxMzMi_pc
I am sending subscribers via webhook to Klaviyo, the first step (form) captures the data, but it's not sent to Klaviyo list.
I don't get any error, actually in Pabbly it's just blank: https://prnt.sc/PfzgR1qvmhPU
I enabled single opt-in in Klaviyo so the data should be sent immediately, yet I am not getting anything...
Any thoughts?
Thanks!
olimckenna — Reply ·
Solved! I had to edit the opt-in settings not only globally but also for each list!
Thanks for the update @olimckenna
