Lead Connector Issue - Field Mapping
Status: Closed · Asked by Alastair Macartney - Wizard Room on · 0 views
Having issues with passing too much data across. More in the loom here: https://www.loom.com/share/a857b368a4b84b34a99a5e3be4985632
Thanks for any help.
Having issues with passing too much data across. More in the loom here: https://www.loom.com/share/a857b368a4b84b34a99a5e3be4985632Thanks for any help.
Hey, I believe you have to do is turn the "Map field" toggle on and then delete everything so that it is blank.
I tired that but it didn’t work.
It wouldn’t let me delete anything.
In any of the custom field of yours, you can either pass the exact same value as the option shows or you can leave the fields empty.
E.g. -
