LeadDelta to Notion using tags
Status: Open · Asked by justs on · 0 views
justs — Question ·
I have setup an automation between LeadDelta to Notion where LeadDelta entries are added to a Notion database when a new tag is applied. The problem is that every entry in LeadDelta that I tag ends up on the Notion database. I only want entries with specific tags to make it onto the Notion DB. I can't seem to figure out how to do this. Any thoughts?
Hi @justs,
You can add a Filter to your workflow and specify the TagId for which you want the next step to be executed. I have added a Filter to your workflow on your behalf, which will prevent the addition of data to your Notion if the applied tag is not *SL Resource. You can add multiple OR CONTITIONS to your workflow in case you want to specify other tags as well.
youtube.com/watch?v=RVoCVvcdk4I
justs — Reply ·
Hi @justs,
Thank you! I actually deleted that filter becasue I had no idea how it got there. LOL Now I know and I also now know how to get the results I wanted. Thanks again for the prompt action!
On another note, it appears that only new items are actionable with LeadDelta+Notion. Any chance that the ability will be added so that we can update a Notion record when a LeadDelta condition is met?
You can follow the steps given in the video shared below to update a particular item in your Notion database.
youtube.com/watch?v=oAI7LR7ER98
justs — Reply ·
One last question, anything that can be done about this error? About 60% of my connections have commas in their industry label.
We have a workaround related to your concern where we have found a lookalike of a comma symbol which you can use to replace in your string.
Single Low-9 Quotation Mark (‚): This character resembles a comma but is oriented differently.
justs — Reply ·
That would be great except that I don't control the comma, LinkedIn does. This is the way it appears on LinkedIn and how it is imported during the automation.
As far as I can tell there's no way to change or create some type of rule or something that changes the comma during the synchronization process.
