Limitation for iterator & get rows
Status: Open · Asked by 99 Interactive on · 0 views
99 Interactive — Question ·
as per my understanding, please correct,
1. iterator can work for 500 GS rows (max)
2. get rows for how many records can be fetched ?
Hey @99 Interactive,
1. Iterator can process more than 500 rows
2. It can retrieve data up to the maximum number of rows in your spreadsheet.
99 Interactive — Reply ·
It means GETROWS can fetched all the available records at once .?
Yes, you just need to specify the range and it will fetch the date in that range.
