LinkedIn Connection Weakest
Status: Closed · Asked by sourav04 on · 0 views
Of all the connections that I have set up, the LinkedIn connection is the weakest of them all. 3/5 times the connections fail. You can check the history to understand. Earlier I tried to club it in one workflow but now I have divided it into 2 separate workflows for simplicity's sake and it's still having issues. I have tried reconnection numerous times. Also, during reconnection, I keep facing issues. The profile doesn't show up or it disappears.
Any help on this is appreciated.
Regards,
Sourav
Hi,Of all the connections that I have set up, the LinkedIn connection is the weakest of them all. 3/5 times the connections fail. You can check the history to understand. Earlier I tried to club it in one workflow but now I have divided it into 2 separate workflows for simplicity's sake and it's still having issues. I have tried reconnection numerous times. Also, during reconnection, I keep facing issues. The profile doesn't show up or it disappears.
Regards,
Sourav
Hey @sourav04
We're still looking over your concern and will update you. The issue seems to be associated with the Linkedin authorization token which is expiring after a couple of duration.
Thank you so much,
Looking forward to hearing from you.
