LinkedIN Form Integration Problem
Devesh
Not able to coonect linkedin form even after creating a new connection.
I have got 4 leads on LinediN ads still it is showing 0 response.
Hey @Devesh
It seems that the connection you are using does not have sufficient permissions to retrieve the leads data from your incoming lead form.To resolve this, ensure that the account has the appropriate admin role or Lead Gen Forms Manager permissions for the LinkedIn Page. If you're using a third-party tool to access the leads, check that the tool is properly authenticated and has the required permissions.
