Load Clickup with GitHub Project
Status: Closed · Asked by jSchneider on · 0 views
jSchneider — Question ·
I have set up Pabbly to add a Clickup task when a new issue is created in GitHub, but is there a way to bring in all issues for a GitHub repository or project? Is there a way to bring in Milestones?
Hey @jSchneider
You can get the issues one by one as a new issue gets in your Github trigger response. You can refer to our tutorial video for better understanding -
youtube.com/watch?v=uIzW8_Z9rjU
Further, the same procedure you can follow to bring the Milestones' when one of milestone created, closed, opened, edited, or deleted.
jSchneider — Reply ·
Thank you for NOT answering my question. I have an existing project with a bunch of issues in GitHub. I want to pull them into Clickup to track time on the project. The issues are already existing and the Issues setup in Gabbly only works when their is a change. How can I do a one time update to Clickup to pull in all the existing Github issues?
