LTD running out
Status: Closed · Asked by JEREMY TANUARDY on · 0 views
Hi Pabbly team, my ltd credit almost running out (im using 3k limit lifetime)
I see only option is to upgrade
What happen to my lifetime subscription when i upgrade?
Thank you!
You can simply click on the "Upgrade" button and can purchase any suitable plan in order to add more tasks to your Pabbly Connect account. You will have the option to purchase either monthly or yearly or 2-yearly or 3 yearly plans.
Further, your lifetime plan will also be there as it is, and you will get the tasks associated with the monthly subscription & LTD plan both.
@Pabbly, so to confirm. If I have a 10,000 task LTD and then also upgrade to a monthly plan of 12,000 tasks then that will give me a total of 24,000 tasks correct?
Yes correct. You will have 24000 tasks in that case.
