Lulu Print API integration issue
Status: Closed · Asked by jonatpak on · 0 views
jonatpak — Question ·
Hello team,
First thing first :
Thank you for welcoming me here and good day to you all.
Now,
I'd like to report an issue with the Lulu Print API integration !
Actually, it "works" but there is one big issue with the way this is set up.
Please let me explain the lulu order process first so that you can get it :
1. A print order is being sent to lulu via its API
2. The print job appears in https://developers.lulu.com/print-jobs
3. The print job is paid on the previous platform
4. The print job is being processed by lulu
Here the issue :
Even though I set up my lulu credentials API within Pabbly,
my orders do not appear within my developper dashboard on lulu...
BUT,
the order was properly created on a different developper account !
Please look at this mail from their support :
Thank you for your reply! I apologize for the continued issue.
I was able to locate order 517617 in our system, but it is listed under a different email address - [EMAIL]admin@pabbly.com[/EMAIL]. Do you have access to the Developer Portal account associated with this email address? I will be happy to assist you in gaining access, if needed.
Warm regards,
K
Lulu Press, Inc.
Could you please tell me if I made a mistake with my integration or if it's an issue with how Pabbly Connect itself is set up ?
Best regards,
Jonathan
Hey @jonatpak
We are currently looking into your concern and we will update to with an update soon. Kind patience will be highly appreciated.
Thanks!!
Hey @jonatpak
We have made some updates in the integration and would like you to re-authenticate the Action step of Lulu application and test the workflow.
Let us know how it goes.
jonatpak — Reply ·
Hey @Supreme Verma
Sorry for the long delay, I actually took a few weeks off.
Now, I'd still like to come back to you :
The integration with lulu now works perfectly !
Thanks a lot. Keep up the great work :)
