Mailerlite group issue
Status: Closed · Asked by Simplify on · 0 views
Simplify — Question ·
I'm trying to set up an integration using Mailerlite. When trying to set up the workflow, I select "Subscriber Added to Group" ... but despite a successful connection, no Mailerlite groups are ever shown to me so I can choose the particular Mailerlite group I want to use.
Is this a glitch? Am I doing something wrong? Or is this rule for any time a subscriber is added to ANY group I have in my Mailerlite account? Which would be... not ideal.
Please advise, thanks!
Pabbly — Reply ·
Please check the first part of video and confirm you're doing exactly the same process at your end -
youtube.com/watch?v=6XfcRBmxQaA
Simplify — Reply ·
I watched the video and was able to get one workflow moving successfully — Group1 in Mailerlite to List1 in Mailercloud. Thank you. However, in attempting to make a second, similar workflow — from a Group2 in Mailerlite to a List2 in Mailercloud — I realized that the first Pabbly workflow had pulled in my new test subscriber to Mailercloud List1, even though the subscriber was added to Mailerlite Group2, not Group1.
So I ask again: does the Pabbly Trigger Event "Subscriber Added to Group" for Mailerlite mean ANY subscriber added to ANY Mailerlite group? That… would not be good. :oops: I need to be able to specify WHICH group's new subscriber triggers an event.
Hey @Simplify
You can use the Filter action step in your workflow after the trigger event which will work only for the respective Group whcih you wanted to process.
Please check out the following screenshot for your better understanding.
Simplify — Reply ·
A-ha. Thank you! ????
