Many Chats + Wix Connection
Status: Open · Asked by Miami Friendors on · 0 views
I have a connection between Many Chats and Wix to create a new contact whenever the trigger goes off. I have various new emails that should have been triggered to be added to Wix, but the connection is only catching 20% of the new responses. Here is the workflow: https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTY1MDYzZTA0MzU1MjZmNTUzNjUxMzIi_pc
Any thoughts?
Thank you!
Hi @Miami Friendors,
The trigger used in ManyChat is based on descriptive webhooks and captures whatever data the application sends to us. We do not have any control over the data that ManyChat sends to Pabbly Connect. If the data is not sent from ManyChat's end, your workflow won't be triggered.
You can try testing this on Webhook.site to see if you are able to capture all the responses there or not.
