Many Chats + Wix Connection
Status: Closed · Asked by Miami Friendors on · 0 views
Hi @Miami Friendors,
The trigger used in ManyChat is based on descriptive webhooks and captures whatever data the application sends to us. We do not have any control over the data that ManyChat sends to Pabbly Connect. If the data is not sent from ManyChat's end, your workflow won't be triggered.
You can try testing this on Webhook.site to see if you are able to capture all the responses there or not.
youtube.com/watch?v=mnJFZxwhiEQ
