Manychat and Custom Field entries are showing as {{cuf_8082019}}
Status: Closed · Asked by champayne on · 0 views
champayne — Question ·
Hey guys,
I have created a flow that pulls from Manychat to Go High Level and the custom field entry is showing up as this > {{cuf_8082019}}. The field vary from text to dates. I did change the date field in many chat to text to make things easier however it the field is still showing as cuf etc.
Can any one shed some light on this please?
Hey @champayne
Kindly re-capture the webhook response once, seems like the test submission which you have made to capture the trigger response might not contain anything/ the default value which you have shared.
So, kindly try re-capturing the webhook response once and then try again.
