MCP to connect Pabbly Connect with Claude
Status: Closed · Asked by Ravi Mittal on · 0 views
Why is there no MCP to connect Pabbly Connect with Claude? Right now there are specific tools which can be connected to MCP server but I am looking for a complete workflow which can be controlled using Claude. Something like is possible in n8n, where in Claude we can connect n8n using connectors. Same way I am expecting Pabbly Connect to be there with MCP connectors.
Hello Ravi,
Thanks for contacting us.
Unfortunately, the feature to connect the entire workflow in Pabbly Connect with the MCP server is not available. You can only activate actions in the workflow. Further, you can submit your feature request at this link - https://pabbly.featureos.app/b/Feature-Request
You can add your Feaure request on the board and others can also upvote so that we can add new feautures on priority based on the feedback.
Adeel Akhtar
🌐 Pabbly.com
