MemberPress : Create Coupon - Issue
Status: Open · Asked by Archer on · 0 views
I am having some issues with the MemberPress: Create Coupon flow.
First - The Coupon Code is a *Required* field but it says right in the notes below it that you need to leave it blank for a unique code, which I want.
Second - There is no entry field for 'Applies To' (for a membership level) and it does not appear that the coupon code works without it.
If I change the 'Applies To' to one of the membership levels then the code it generated works.
Thanks for the help!
Hi @Archer,
Please allow us some time to look into this. We will get back to you with an update soon.
