MemberPress Help Needed
Status: Closed · Asked by EntrepreneurPAL on · 0 views
EntrepreneurPAL — Question ·
Hi, i'm new to Pabbly, however I see there are some existing workflows between the services I want to connect, such as: https://www.pabbly.com/connect/integrations/lemon-squeezy/memberpress/ and https://www.pabbly.com/connect/integrations/systeme-io/lemon-squeezy/ my question is do I have to create each individual workflow between Lemon Squeezy and MemberPress or can I simply bulk input/connect the required/essential workflows?
Thanks,
Christian.
Hello @EntrepreneurPAL,
Yes, you can create the workflows directly by clicking the "Try Now" button. After that, you can make any necessary adjustments within the workflow. Please note that bulk creation is not possible; you will need to click the "Try Now" button for each workflow you wish to create.
EntrepreneurPAL — Reply ·
Hi Preeti, okay thanks for letting me. How many connections can I test with the free plan per month? I see it says (100 Tasks Every Month), does this mean you can have unlimited connections, or are connections limited too? Thanks.
There’s no limit on the number of connections or workflows you can create under the free plan. However, please note that the task limit is 100 per month.
Hi Preeti, thanks for getting back to me, that's good to know. Can I ask what specifically deemed as a task? For example, are each of the following integrations: https://www.pabbly.com/connect/integrations/lemon-squeezy/memberpress/ deemed as one task? Obviously for each member/user per trigger? I'm guessing each integration uses 1 trigger/task per interaction, correct?
Triggers in pabbly are considered as free task. For exampe for the workflow in the attached image, 1 task would be counted towards your task count(100) on each run. A task would be consumed to create coupon in MemberPress.
Okay, got it. Thanks for all the info. That's great.
I hope all your queries were answered. We’d appreciate it if you could share quick feedback on the support received:
Thank you for your time.
