Merge Values
Status: Closed · Asked by mije on · 0 views
mije — Question ·
Need some help with this issue. So how can I merge the 2 options. So they can be sent out as 1, meaning name and value?
In this case I am getting the Field Name and the Value separate. I know about text formatter that can let you bring the 2 things together, but I want them to be like the results from the API that it returns Name : Value in the example I uploaded it would be link_click : 335 and I could just select the option from the dropdown. Thanks!
Hey @hcarreon
Could you please tell us what API you are using? And you can try to get the desired result on API Response in an array-like you wanted in a single field by simply switching off the simple response and then re-do the Action/Trigger.
If the API allows showing the result in a single row then it will appear.
Else if the API doesn't respond accordingly, so we have managed to do a workaround which you can try at your end in the given workflow.
Example -
