Meta node issue
Status: Closed · Asked by Lorenzo Giacomini on · 0 views
Good morning,
I’m having a problem with the Meta trigger. When I submit a test lead, I get this error, but the connection is fine. Can you tell me why?
Hello there,
Thanks for contacting us and sharing the Workflow.
As we checked the workflow and the task history, the workflow is triggering normally.
We fetched the same data in the Trigger, which you can map in the following actions.
Kindly make some real time submission to the Facebook Lead Ads form and then check the Task history.
Adeel Akhtar
🌐 Pabbly.com
