Mindbody Webhook Issue
Status: Closed Β· Asked by Vent Admin on Β· 0 views
Vent Admin β€” Question Β·
I'm trying to use the Mindbody β†’ Client Created trigger in Pabbly Connect.
The initial webhook registration appears to work correctly. Pabbly receives the event information (client.created) and generates a webhook URL.
However, immediately afterward, it makes a second request:
  • Method: PATCH
  • URL: https://push-api.mindbodyonline.com/api/v1/subscriptions/?
  • Response: HTTP 405 Method Not Allowed
It looks like the PATCH request is being sent to /subscriptions/? without a subscription ID.
Has anyone else run into this with the Mindbody integration? Is there a workaround, or is this a known issue?
Thanks!
Pabbly Support β€” Reply Β·
Thank you for reaching out.
We'll be happy to investigate the issue you're facing with your workflow.
To help us review and troubleshoot the issue, kindly share the following details:
  • Workflow URL of the affected Pabbly Connect workflow.
  • A confirmation from your side stating:
 "I confirm Pabbly to access and test my workflow for troubleshooting purposes."
Once we receive the above details, our team will review the workflow, investigate the issue, and get back to you with our findings or the next steps.
Anushka Sahu
🌐 Pabbly.com
Vent Admin β€” Reply Β·
Thank you!
__________________________________
The Vent Team
4013 E Main St, Ventura, CA 93003
The Vent: Human Performance Center
(805) 995-9030 Calls
(805) 318-3278 Texts
On Mon, Jul 13, 2026 at 11:28β€―PM Pabbly Support <support@pabbly.com> wrote:
Anushka Sahu
🌐 Pabbly.com
Before we investigate this further, we request you to please follow the setup guide below and create a new Mindbody connection by following each step carefully:
Documentation: https://forum.pabbly.com/threads/mindbody.24884/
Once you've created a new connection, please test the trigger again.
If the issue still persists, we'd be happy to investigate it with you over a live meeting. Kindly schedule a meeting at your convenience using the link below:
Schedule a Meeting: https://calendly.com/d/d2dg-tgd-g92
During the meeting, we'll review your setup and investigate the issue in detail to help resolve it.
Anushka Sahu
🌐 Pabbly.com
This is a gentle follow-up regarding our previous email.
We wanted to check if you had a chance to go through the documentation and create a new Mindbody connection by following the steps provided.
Once you've created the new connection, kindly test the trigger again and let us know the outcome.
If you're still experiencing the same issue, we'd be happy to assist you further over a live meeting. You can schedule a meeting at your convenience using the link below:
We look forward to your update.
Anushka Sahu
🌐 Pabbly.com
Back to all forum threads Β· Log in to reply
