Missing Features?!
Status: Open · Asked by Franzo on · 0 views
Where can I find all the functions for creating an array, adding elements, working with arrays, and everything else? I don't see the "append text" or "compose" functions in the text formatter or the data store functions?
I'm iterating with the iterator task and I need to save the return value for each loop.
Can anyone help me?
Thank you very much.
Hi @Franzo,
Pabbly Connect does not have an internal application that can be used to accumulate data across all iterations. If you would like this feature to be added, you can submit your request on our dedicated platform:
https://roadmap.pabbly.com/b/Feature-Request
In the meantime, you can use the Google Sheets action step to store your data instead.
If you could describe your complete use case in detail, we can guide you in the right direction and suggest alternative approaches to achieve your goal.
Arshil Ahmad
