Missing tons of triggers for AgileCRM
Status: Closed · Asked by francois.blq on · 0 views
Hi guys
hope you are doing fine
i see only 2 triggers for Agile CRM webhook integration : "contact created/updated" and "opportunity created/updated"
but Zapier and Integrately offer so many more triggers (see screenshots attached) :
new event, new task, new ticket, deal milestone changed (this one is SUPER important), contact being tagged , ...
any plan to add these triggers ?
thanks for your time
take care
Hey @francois.blq
If you want to request for updating any existing integrations with triggers or action, please send us the request here and upvote it
- https://pabbly.hellonext.co/b/Update-Existing-Application
Our integration team will look into it.
Has anything developed here? It's quite dissapointing that there are only 2 triggers, Zapier has over 8. Can there be new triggers such as
- New Tag to contact
- New Deal
- Contact moved to new list
Hey @Timi
To have our technical team construct endpoints for you, kindly create a request on HelloNext https://pabbly.hellonext.co/ and upvote it.
Please make sure that whatever endpoints with the data features that you required to update in the HelloNext so that our team will construct those endpoints with the required features for you.
https://pabbly.hellonext.co/p/update-and-add-new-triggers-to-agile-crm
I’ve done this already and hope it can be implemented considering Agile CRM is one of the biggest platforms. Thanks
Timi
